TwinTurbo.NET: Nissan 300ZX forum - Re: Why would my 10A engine control fuse keep blowing? And is...
orian63
on June 29, 2015 at 12:19 PM
posted by Adamo
on June 26, 2015 at 05:24 PM
i had the same problem it took me 3 weeks to figure it out its the bulb check relay its located next to the fuse panel.if you need exact location just e mail me back and i will send you a wire diagram.
Adamo
17:24:53 06/26/15
10A is a LOT to keep blowing
OverZealous (CT)
18:18:58 06/26/15
Yes i figured but was wondering where/what the problem is.
Adamo
19:54:36 06/26/15
Actually that 10amp fuse in the relay box is part
ttz'in (norcal)
02:22:02 06/27/15
Thanks for the info, what was wrong with the VTC solenoid? (n/m)
Adamo
09:34:30 06/27/15
Electrical issue in solenoid. Turn key to start, fuse
ttz'in (norcal)
19:10:43 06/27/15
Re: Why would my 10A engine control fuse keep blowing? And is... -
orian63
12:19:06 06/29/15
B.C. relay & others are on backside of fusebox. (n/m)
ttz'in (norcal)
16:20:58 06/29/15
Email sent. I pulled the fuse panel, I see some relays, in a
Adamo
17:01:30 06/29/15
Check your email.. (n/m)
ttz'in (norcal)
17:35:05 06/29/15
Two brown relays are IGN & DEF ....
ttz'in (norcal)
17:40:45 06/29/15
Update! Swapped out the CB relay and changed the fuse...
Adamo
07:05:09 06/30/15
Found where the issue is, DS VTC solenoid, and it looks like
Adamo
16:26:28 07/01/15
